+1 to the points being made. 289s rip to high RPM effortlessly thanks to their short stroke, but to take advantage requires a lot of gear. Making them 'even more high RPM' by using a meaner cam will hurt mileage and streetability.
Realistically, you have a few very good choices for making wicked tire-melting power with a 289 that's still got good behavior, and some of them can be put together:
1) use forced induction. A supercharger or turbo can add enough torque to make it scary fast. Often, it will actually improve streetability or mileage.
2) use Nitrous Oxide. Laughing gas is no joke. You get on the throttle and hit the bottle, and you won't be able to see them crying behind you for the tire smoke.
Either of those strategies will require a well-thought-out build, with good forged pistons, and ring gap that's intended to work with your setup.
The third option is to just do a really good N/A build with good heads, intake, cam, and headers. You can always add nitrous or a turbo, so long as you built it to withstand the boost too.
No matter what you do, keep in mind you need to spend good money reinforcing your chassis, brakes, steering, and set up your suspension to handle the increased power. You don't want a Wile-E-Coyote one-shot ride, when you put that much time, effort, and money into a car like this. And don't forget the seatbelts.
