1 - 2 of 2 Posts
Anyone have experience with the Ford Motorsport Aluminum J-Code Heads M-6049-J302
I am trying to compare them with aftermarket heads like the Edelbrock Performer of the Trick Flow 170?
I am looking for heads for my 94GT. It will be a mild build using GT40 intake, cam, header, off roads H-pipe, Magnaflow exhaust, 24 lb injectors, bigger TB & Mass air etc.
There is a set of the J-code heads for sale for $1000. They are mildly ported. What is a fair price for these or would I be better off looking for a more modern design?
Not looking for a race engine, Goal is a daily driver, with a bit extra power in the 300-350 HP range.
You can probably get to 300HP at the flywheel with them. From the 3 you mentioned in terms of performance order it goes Trickflow, Edelbrock and then the Ford Motorsport J302 ones. Here is an older link showing the flow:
1 - 2 of 2 Posts
