1 - 1 of 1 Posts
This is a revised list from my July 27th posting. Changes from that post are highlighted in blue. Any price changes take effect with this posting. Prices do not include shipping. Just email me your ZIP Code and check on quickest or cheapest actual shipping cost to you.
I'm still cleaning my 15-20 year accumulation of mostly 1969 Mustang parts before I move again. This is still a partial list--I will add to it as I go through my stash, but don't hesitate to call me with your need list in case I do have it or send me your email address and I’ll send you updates as I make them.
Joe Hank, Land O Lakes (Tampa), FL 34639
Email address: [email protected]
Phone: (813) 929-9187
As of: August 26, 2004
Engine Parts
69 /\ 351W/4V intake manifold $100
69 351W Camshaft and lifter set (used) $35
70 /\ 351W Harmonic Balancer (4-bolt) (3) $45
70 /\ 302/351W front pulley (3-grove) (2) $35
69 or 70 351W timing cover (4) $35
68-70 302 Air Cleaner ass’y $75
68-70 302 exhaust heat riser $35
69 302/351W Valve covers $25/set
68-69 24” Radiator (for w/AC) (2 core) $75
5-bladed fan (stamped D4OE-8600-AA/G73 $45
7-bladed fan (stamped D1DE-8600-BA/A75 $45
69-70 Under engine frame cross member $25
69 302 Single Exhaust system (Original Ford)$75.
69/\ 351W Oil Pump (used original) $25
69/\ 351W Oil Pick-up Tube Ass'y $35
289/302 Oil Pump (high volume) new in box $35
69-70 302/351W water outlet gooseneck $10
68 289/302 water outlet gooseneck $10.
Transmission Parts:
67-70 289/302 Clutch Equalizer Bar C7ZZ-7528-G $35
67-70 289/302 Clutch Equalizer Bar C7ZZ-7528-G $25
69 351W Clutch Equalizer Bar $45
65-68 Clutch Fork (C5OZ-7515- ) $35.
70 /\ Clutch Fork (like new) (DODA-7515-B) $45
69 302 C-4 AT flywheel/flexplate (157 teeth) $45
69 351W FMX AT flywheel/flexplate (164 teeth)$75.
C-4 AT Insp Plate $5
FMX AT Insp Plate $10.
69/\ FMX AT (31-spline) trans yoke $45.
69-70 Drive shaft (MT/C-4 trans) $75
69-70 Drive shaft (FMX trans) $75
69-70 MT/C-4 Trans Crossmember $20
Differential/Rear End Parts
65-73 Gear Ass’y Pinion Shaft $10.
Front Brake Parts:
68-70 Power Drum Brake Setup (Booster, master cyl,
PB pedal (AT), intake vacuum fitting & lines) $175
69-70 Brake pedal support bracket (drum brake) $35
69-70 Std Drum Brake Pedal (Auto Trans) $25
Steering & Suspension Parts
69-70 Front Sway Brace, Std. suspension, w/mounts $25
69-70 Outer Coil Spring Cover (Rt/Lt) $20 ea/$35 pair.
69-70 Front Coil Springs, 302 $45 pair
69 Mustang front shock absorbers $10 pair
68-70 power steering drag link $25
68-70 Power Steering Pitman Arm $35.
Wheels & Wheel Covers:
69 Wheel Covers, standard Mustang $15 ea/$50 set.
67-70 Wire Wheel Covers (1 set) (very nice cond) $100 set
68-69 Style steel wheel beauty rings $35 each
68-69 Style steel wheel GT center caps (GT emblem) $35 each
Air Conditioning Parts:
66-73 Air Cond. compressor (2) $45
65/\ Idler/belt adjust pulley $15
71/\ 351 AC Head Mounting bracket $45
(cast # D1AA-2882-BA).
Body Parts:
69 Frt Headlight Ext, Rt (needs work) $50
69 Bracket, Fender Ext to Fender $5
69 Headlight Buckets $12.50
69 Headlight Bucket Spring $2.50
69 Headlight Bucket Adj Screw Ass'y $2.50
69 Headlight wiring harness (Rt or Lt) $20
69 Headlight bezel (inner/blk plastic, Lt) $20
69-70 Frt Fender Splash Shields $80 Set of 4
Front (Rt or Lt) $20 each
Rear (Rt or Lt) $25 each.
69 Front splash panel $25
69-70 bumper support bracket-main (Rt) $10
69-70 bumper support bracket-side (R or L) $7.50.
67-70 Hood hinges (w/springs) $20 each/$35 pair
69-70 Louvered Front Cowl Cover $50
69-70 Rear Window External Trim $15 each/$50 set (4 pcs.).
69 Grande rear fender extension $45 each/$80 pair.
69 Coupe rear fender extension $35 each/$60 pair.
69 Coupe rear quarter similuated scoop (w/chrome trim) $100 pair
69-70 Rear bumper (very good chrome) $45
69-70 Coupe/Conv trunk frame lower
corner (Rt or Lt) $20 each/$35pair.
Doors/Glass Hardware:
69-70 Door Latch Release Ass’y (inside door) $35
69 Coupe Door Glass (clear) (Rt or Lt) $100 each
69 Coupe Door Glass (tinted) (Rt or Lt) $125 each
70 Coupe Door Glass (tinted) (glue-in) (Rt or Lt) $125 each
70 Coupe Door Glass (clear) (bolt-in) (Rt or Lt) $150 each
70 Coupe Door Glass (tinted) (bolt-in) (Rt or Lt) $175 each
69-70 Fastback Rt Door Glass (clear) (glue-in) $125
69-70 Coupe weatherstrip channel $100 pair
69-70 Fastback weatherstrip channel $100 pair.
69 Coupe Rear Quarter glass (tinted) (Rt or Lt) $65 each
70 Coupe Rear Quarter glass (clear) (Rt or Lt) $50 each
70 Coupe Rear Quarter glass (tinted) (Rt or Lt) $65 each
Early 70 Coupe/Conv Tinted Glue-in Glass Set $375
(Note: Early 70 Mustangs came with glue-in glass which is
about ¾” longer than 69 glass. 70 qtr glass is also ¾” narrower
than 69 quarter glass. Accommodates change in seal from door
glass in 69 to Qtr glass in 70).
70 Coupe/Conv Clear Bolt-in Glass Set $375
70 Coupe/Conv Tinted Bolt-in Glass Set $450
(Glass set = 2 Door Glass + 2 Qtr Glass)
69-70 Fastback Rear Quarter glass (clear) (R or L) $50 each
69-70 Fastback Rear Quarter glass (tinted) (Rt) $65
69-70 Door glass regulator/scissors (Rt or Lt) $35
69-70 Rear Quarter Window Regulator (Rt or Lt) $25
69-70 Door window guide bar $15.
69-70 Coupe Rear window glass, (clear) $45
69-70 Coupe Rear Window External Trim $15 each/$50 set (4 pcs.).
69-70 Windshield wiper motor ass’y $45
69-70 Windshield wiper linkage ass’y $25
69-70 Mustang Interior Parts:
69-70 Seat Rails/Tracks $30 set.
69-70 Seat rail/track – handle side only $20.
69 Std black Instrument Cluster $95
70 Std black Instrument Cluster $95
69-70 RH Mach I bezel (woodgrain) w/round clock $100
69-70 RH large plastic dash bezel-plain $20
69-70 RH rectangular clock delete panel $15
69-70 lower dash panel (w/o AC)(metal) $75
69-70 Glove compartment ass’y $25
69-70 Kick Panels . $10-$20 each
69 Steering column ass’y $100
69-70 Rear seat side panels (steel) $25 pair
69-70 Right Arm Rest (Black) $15
69-70 Right Arm Rest (Red) $20
69-70 Radio/Heater Bezel Trim - Red $15
69-70 Dash Trim Caps-Black or Red $7.50 each/$25 set of 4
69-70 Sunvisor Assy-Red $15
69-70 Front Window Crank-w/blk knob $7.50
69-70 Rear Qtr Window Cranks-Red (4) $7.50
69-70 Knob, Window Crank-Red (2) $5
69-70 Inside door opening lever – Rt. (4) $15
69-70 Inside door opening lever – Lt. (3) $15
69-70 Rear Console Ash Tray-Red $10
69-70 Sunvisor center holder-Red $2.50
69 Steering Column Plastic Trim (black) $5 (broken tabs)
69-70 Heater Box Assy (w/o AC) $75
69-70 Emergency Brake pedal mechanism $45
74 Ford AM Radio (D4TA-18806) works great $15
77 Aeronutronic Ford AM Radio (works great) $15
78 Ford AM-FM 4-chnl stereo radio $25
Interior - Steering Wheels & Parts
69-'70 Steering Wheel Center Pad, Ford/Mustang/Cougar std (2 spoke), dark red, excellent condition, has Cougar center emblem that can be replaced with Ford or Mustang emblem. $25.
69-'70 Steering Wheel Center Pad, Ford/Mustang/Cougar std (2 spoke), black, excellent condition, has Ford center emblem that can be replaced with Mustang or Cougar emblem. $25
68-69 Horn Ring, Mustang/Cougar/Ford original, used but in excellent condition, not bent or cracked. (Sells for $75 used original or $50 repro in catalogs). Asking $35
69-'70 Steering Wheel, Ford/Mustang/Cougar standard, black, fair condition. Two full cracks at top and bottom of outer wheel. One full crack on right side above spoke attach point. Two partial cracks on both sides near spoke attach points. Plastic on spokes is not cracked and is complete. All cracks are cosmetic only (can be covered with steering wheel cover). Steering wheel is fully functional as is. Asking $15.
Many more parts are available—please call for your specific needs. Prices do not include shipping. Just email me your ZIP Code and check on quickest or cheapest actual shipping cost to you.
(813) 929-9187 Email address: [email protected]
1 - 1 of 1 Posts
