This direct-fit replacement fresh air vent assembly mounts under the dash on the driver side near the driver's left leg. This OEM-style part allows outside air to enter from the hood cowl vents and then flow into the passenger compartment. The amount of air flow can be controlled with the fresh air vent cable, which is included with this assembly. This assembly should be replaced whenever you replace the lower cowl on your pony since installation is easier for both and the parts often rust or corrode on their adjoining joints. Order yours today!
Tech Tip: This Driver Side Fresh Air Vent Assembly also includes the air vent cable.
