Front brake pulling under hard braking....
638 5
What are the likely causes of the right front tire pulling me to the right under hard braking? Is it a bad wheel cylinder, or proportioning valve, or both? I redid the rear brakes, but not the front, and put a new MC on...It just started doing it recently....I got 4 wheel non-power drums all the way around....
RJ
68 Diamond Blue Coupe
Sprint Promotion A
289 2bbl with a C4
Click Here For Home Page
Had this exact same problem on a '65 coupe some years back. Turned out to be a frozen self-adjuster mechanisim. Could be the lining has become contaminated either with grease (bad seal) or fluid from a leaking wheel cylinder. I've also experienced cracked linings which make a wheel brake very grabby. Proportioning valve controls only the rear brakes, modulating pressure to prevent premature lockup, so doubt it would be that. Having said that, 4 wheel drum brakes don't use a proportioning valve in the system. Was the car previously a disk brake car?
65 Hi-Po F/B
67 GTA F/B (small block)
MCA 27479
No discs ever....so I guess I can rule out proportioning valve....I guess what I am thinking of is the distribution block that is on the apron across from the MC....
RJ
Sprint Promotion A
289 2bbl with a C4
Most likely one cylinder is leaking fluid on the linings or one piston in the left cylinder is frozen. Not all that unusual. Should be obvious when you pull it apart.
