1 - 20 of 33 Posts
64.5 F Code Mustang Coupe 302 V8
Hi guys,
My next project is a front disk brake kit, I am thinking of going power brakes.
What kits have you guys installed and or what would you recommend?
Discussion Starter · #2 ·
The wheels on the car now are 15inch legendary wheels.
Are you racing the car or cruising Dairy Queen? Makes a difference.
I went with a power disc brake conversion from Master Power Brakes. I did so after I had to take the shoulder when a vehicle in front of me hit the brakes pretty hard, no way my '70, 351C-4v with manual drum brakes was going to get stopped. Easy to convert with basic hand tools. Would do it all over again.
Discussion Starter · #8 ·
Not racing the car, weekend cruiser but want to upgrade it.
I have the CSRP power kit, and I'm not overly impressed. I'd get the SSBC kit from Rick if I were in your shoes.
I wouldn't trade my manual K-H discs for a power set-up...
Ditto! I removed the Midland booster, swapped 14" rotors and 4 piston 2015 Mustang Brembos. I made a panic stop the other day when a knuckle head pulled out in front of me. I braked hard enough to get some tire squeel, but didn't lock them up. I'd never stopped the 69 as quickly before, even when it had power 13" 2001 Cobra brakes on it.
Discussion Starter · #14 ·
Is there a reason most of what I am reading is to stay away from the power brake system? I understand it will not help brake. Just interested on why so many say to stay manual.
Spammer Hammer
One less thing to break. One less thing under the hood. Looks can be unappealing.
Then what you need is power boost, to decrease pedal effort. No need for disc conversion.
From a performance standpoint, power boost gives zero improvement in braking.
As a cruiser, if your drum brakes are properly maintained, they'll stop just as well in one panic stop as discs. The disc brake has a clear advantage in repeated braking, because it recovers much more quickly. Quick recovery is not an issue with cruising, unless you are nutz like me.
Rick (NPD) just posted that he has lots of SSBC kits available...deeply discounted.
I wouldn't touch an SSBC kit at this point, given they are currently belly-up. Good luck getting after sale support, and/or replacement parts down the road.
Reactions: Israel
What size wheel do you need to run a 14" rotor?
1 - 20 of 33 Posts
