Wifes Mercedes makes kind of a grinding sound when cornering hard making a right(left front wheel) Checked the shocks and replaced the fronts, replaced the sway bar ends and the tie rod end-they all looked kind of shot. 200K miles. Repacked the wheel bearings, didn't look chewed. Darn thing still grinds a little.
When I pull on the wheel while it's off the ground, if I push/pull on the top and bottom, no play,. push pull on the sides, there is a little play.
Only the left side does it. Sound like steering? Ball joints? This is an 83 380sl that is actually pretty similar to a Mustang in design.
Thanks.
J. Boggs
Thanks.
J. Boggs
