I am in the process or rebuilding my front suspension. While installing my new spring perches I noticed the tab that retains the bottom spring coil. Where is this tab oriented when properly installed? Toward the back or front of the car? Near the shock tower, or away from the tower? Does it matter? Thanks in advance for the help.
just did my '65, when installing the coil spring back in ensure you keep it up against that "tab",as it will tend to shift on you as you release tension. Have someone help you if possible.
yes, if its not on the money it'll "pop' on you as you drive along your merry way. have a good one.
