If you just replaced your old fuel sending unit with a new one or just upgraded to an Autometer gas gauge with your stock sending unit here's why you don't get the correct reading:
The problem is that the new sending unit is a Linear device, whereas the OEM sending unit and gauge are a non-linear device. Ever wondered why the gas gauge was somewhat cocked to one side and that half was not really at the normal half way point? Simply put the two can't communicate correctly and will be right only twice - at empty and full. Everything else will be off by a few gallons. I've tried for years to get it to work correctly, and it won't. Either live with it or try and find an OEM sending unit.
Top gauge is a nonlinear gauge, and bottom is a liner gauge. The 1/2 mark is closer to the Full on the nonlinear gauge. It has to do with the electrical winding of the fuel sending unit. The nonlinear has the windings start out compact and then as they get to the 1/2 mark the windings start to get larger in the loop.
On a linear sending unit the electrical windings are all even across the entire range.
Anyway I hope this will help clear up why your gas gauge is now registering about 1/4 tank off.
