I've got the Holley Sniper and Aeromotive Stealth Gen 2 tank arriving tomorrow from Summit.
Still haven't decided how I'm going to plumb it and it's got me totally twisted up.
I've seen some good ideas here, but I'm still much more worried about the plumbing than anything else with this swap.
I want to use the original 5/16 hardline as the return, and still debating how to do the feed line.
My current favorite idea is to use 3/8 ni/copp hardline, but I'm spinning back and forth over three different possible routes.
1. Parallel the stock line up the driver's side.
A couple of issues here, one of which is it goes through a hole in a frame support that is not big enough to fit the 3/8 line. The other issue is not sure how I'll get to the firewall since I don't want to follow the factory up through the front wheel well since I want to have both return and feed come out the back of the Sniper TB.
2. Mirror the stock routing location except on the passenger side.
Kind of have same issue, not sure how/where to deviate from stock route to get to firewall.
3. Run it up the driveline tunnel. Not sure how to secure it in there since I think it's all thin sheet metal. Also worried about safety of having it in a tunnel near a spinning driveline.
All of the above is further complicated by the fact that the car is fully assembled and I think bending hardline around all the crap under the car is probably well beyond my skillset, and patience, if it's possible at all. Especially with me on my back under the car on jack stands since I have no lift.....
I'm super excited for the Stealth tank and the Sniper, but the plumbing is freaking me right out.
I'd love to hear some ideas/feedback on any of my 3 options above.
For those who have used the factory line as return, any luck modifying it to enter the engine bay and go up the firewall instead of up through the front wheel well to the front of the engine?
Or did you just leave it and u-turn it out of the TB and down around the water pump in stock route?
Has anyone done hardline up the trans tunnel? If so what did you use to anchor it and did you pull it off the the car "put together"?
Also, how did you route the power wire back to the tank? Is it crazy to piggyback it with one of the fuel lines?
Ray
