·Guest
I was in the middle of removing my fuel tank on the 71 coupe, reading my chiltons manual and everything was going great, but I got stuck. I am at the point of taking the filler neck out, and I will type exactly what the manual says and maybe you can help me.
8.Loosen the filler neck to tank hose clamps. (I don't know where to look for these, and there are no clamps around my filler neck that i can find.) Remove the filler neck, mounting gasket, and filler neck to tank hose. (How do i go about doing that?)
Also reading ahead, the next step is to remove the tank to luggage compartment floor pan retaining screws.
I looked all over the trunk floor pan, and cannot find any screws at all. I am pretty sure the tank was replaced by the previous owner and isn't stock, so maybe these things are different than what the chiltons manual says? I figured some of yous had replaced your gas tanks and might be able to give me some advice.
Thanks in advance,
Kalen
Thanks in advance,
Kalen
