I have a 1969 base model convertible, no A/C. I have the dash apart, doing my cluster lights and putting in a new aftermarket (retro style) stereo. Previous owners did some ad hoc wiring over the years and so I am going to sort it out to clean this up.
The fuse box does not have the accessory post/fuse, so I will be adding one accommodate the seat belt warning light/relay that I purchased used. Currently, the stereo is tapped into some wire elsewhere. I guess I could tap into the new accessory post? Unless someone can tell me what the original RADIO (+) feed wire color is? This would be off of FUSE position 1.
Next, I have aux gauges (water temp, oil pressure, and tach). Right now these are tapped into the same "always hot" line that the PO wire the radio with. This means lights are on all day. My question is this..... Would it be too much draw for the 4amp fuse if I were to wire these in with the line feeding the instrument cluster/clock/heater control lights/etc.? I don't have a clock. Would this draw down the voltage current and make my cluster lights even more dim? I like the idea of the lights coming on with the headlight switch but its not a deal breaker. What do most people do?
BTW - I have documented the pinouts of the cluster printed circuit connector if anyone needs it.
