·I've noticed a small gap (less than 1/4") between the sheet metal welded in by the previous owner that is about 4" long. I'm wondering if this can be filled in by something like JB Weld or fiberglass? What is the preferred method?
I'll try to describe the location. /forums/images/icons/smile.gif
Passenger side, where the flooring sheet metal meets the vertical wall of the kick panel. Or if you were looking at it with the fender removed I suppose this would be the passenger side splash panel behind the wheel.
Thanks!
Thanks!
