1 - 11 of 11 Posts
So I came across this video on YouTube where the person replacing his cluster had made a plug system so it's easier to install/remove instead of having to mess with each wire individually.
Has anyone done this? If so, any tips or pointers?
Here is the video, it looks pretty neat/easy but with old Mustang wiring, I wonder if it is truly that easy:
I have done this. It truly is nice when you go to pull the cluster and you can just disconnected as a unit. One thing I would urge would be to add an extra foot a wiring so you can pull the cluster out and then disconnect your plug or you can disconnect it from under the Dash . I just coil up the extra wire under the dash. Also, all of my gauges are aftermarket so I don't have to use anything from the original wiring harness.
Probably wouldn't do it on factory wiring, but if you are replacing the harness, or have a reason to be removing your instrument cluster, it probably wouldn't be a bad idea. Use something like the Molex connectors, There are lots of individual pieces you will need to buy to complete the plugs, and possibly some specialized tools. I use Weatherpack connectors for protecting the connections from the elements but for under the dash, you wouldn't need that, unless you have a leaky cowl.
The 67's have disconnects like that from the factory. There are 3 of them instead of just the one but it makes it pretty easy to get the dash out.
Similar story here - rewired the car with AAW kit and we added connectors (one one but several) so that you can remove the whole cluster (gauges, bezel, rear metal housing) as one piece. I have not had to remove it but good to know I can if needed.
I do this on every car I build. Much easier to remove/replace the cluster without scratching the dash and steering column.
Painless Performance makes plugs/receptacles in various pin counts that are very nice and not that expensive. This is a 15 pin example:
WeatherPak connectors would work fine, too. But they are more expensive and you don't need sealed connectors under the dash.
6" Assembled Black Deutsch 2,3,4,6,8,12 Pin,14 AWG waterproof connector wire
This is what you are needing. I used one when putting in my gauges.
That's a good price on those Deutsh connectors. The kits to assemble them are around $150.
I did it on my 65 and glad I did. I put one connector for the wiring on one side of the speedometer, and did the same on the other side. Definitely easier getting the instrument panel out.
I've done this on both my cars. My advice is to take you time, solder all connections, use shrink tubing and zip ties to make it tidy.
1 - 11 of 11 Posts
