1 - 12 of 12 Posts
Since the idiot light for my oil pressure has i believe been giving me trouble, I've decided to install a proper gauge, what are the advantages or disadvantages of mechanical or electric gauges, tips on installation of both also would help in my decision on which one to chose. Thanks
The advantage to mechanical is having less electrical stuff. The advantage to electric is having less mechanical stuff. :p
I think many people used to feel that mechanical gauges were more accurate, but a good modern electric oil pressure gauge is plenty good.
Personally, I prefer wiring up an electric gauge instead of running plumbing into the car for a mechanical one.
VMF Full-Timer
I installed a mechanical on mine, I know alot of people say that there is a danger of oil line busting, but it has never happened on any I have used. Very simple install. Just my $.02
If you go with an electrical gauge, you'll have to change the sending unit, as they are different for idiot lights and gauges.
Yes, but any good gauge will come with the new sending unit included.
[quote='70 StangMan]I installed a mechanical on mine, I know alot of people say that there is a danger of oil line busting, but it has never happened on any I have used. Very simple install. Just my $.02[/quote]
I never had one fail either, I just prefer electric. I ran all mechanical gauges on my race car and never had a problem.
Electrical is what I'll be using. I don't like the idea of routing, nor having, fluid filled lines going everywhere.
VMF Full-Timer
The bonus of the mechanical is I.M.O., is if you have a oil pressure problem, you will know immediately.My $.02 again.
My Autometer came with the new sendind unit like said...
You'll have to change the senders either way as the mechanical gauges have there own fittings to go in as well...I prefer the mechanical guages.It's not that hard to run the small tubes out to the engine and the only wiring is hooking up the lights.
[quote='70 StangMan]The bonus of the mechanical is I.M.O., is if you have a oil pressure problem, you will know immediately.My $.02 again.[/quote]
As you will with an electrical gauge.
1 - 12 of 12 Posts
