I inquired about this and a few others as well so as promised here are the parts that worked for me. I know there are many ways to run fuel to a carb but I wanted a stainless hard line so that's what I got. I wanted stainless for longevity, safety, and appearance.
I'm sure this can be done cheaper but at this point in my build a couple more dollars is worth it. This works nicely and doesn't require any flaring of the stainless hard line. The line will reach fine but only if you use every single part on this list. You will have to make a few slight bends in help everything line up.
FYI- the fuel line is a dull stainless but a few seconds on a buffing wheel and then hit with some Mothers alumunum and mag polish and she will shine nicely.
pics below.
parts needed:
Edelbrock 1406 Carb which is 600cfm. This also should work with other models, .
Edelbrock 8131 - Edelbrock Single-Feed Fuel Line Kits
www.summitracing.com
Right Stuff Detailing ZPC6602S - Right Stuff Detailing Fuel Pump to Carburetor Lines
(one end has a flare with fitting for pump end. the other end has a bubble flare so cut that off as close to the bubble flare as possible)
Summit Racing SUM-220675B - Summit Racing™ Fuel Pressure Gauge Fittings
Mr. Gasket 1561 - Mr. Gasket Fuel Pressure Gauges
(if not used you will need something to make up that distance as the fuel line just reaches)
Earl's Performance AT915106ERL - Earl's Performance Couplers
Fragola Performance Systems 893005-BL - Fragola Performance Systems AN to Tube Adapter Fittings
(This is a compression fitting and not flaring needed)
Standard mechanical fuel pump -remember Eddy carbs don't like much more than 7lbs and will flood with too much pressure.
pics below.
parts needed:
Edelbrock 8131 Edelbrock Single-Feed Fuel Line Kits | Summit Racing
Free Shipping - Edelbrock Single-Feed Fuel Line Kits with qualifying orders of $99. Shop Carburetor Feed Lines at Summit Racing.
Right Stuff Detailing ZPC6602S Right Stuff Detailing Fuel Pump to Carburetor Lines | Summit Racing
Free Shipping - Right Stuff Detailing Fuel Pump to Carburetor Lines with qualifying orders of $99. Shop Automotive Fuel Lines at Summit Racing.
Summit Racing SUM-220675B Summit Racing™ Fuel Pressure Gauge Fittings | Summit Racing
Free Shipping - Summit Racing™ Fuel Pressure Gauge Fittings with qualifying orders of $99. Shop Gauge Adapters at Summit Racing.
Mr. Gasket 1561 Mr. Gasket Fuel Pressure Gauges | Summit Racing
Free Shipping - Mr. Gasket Fuel Pressure Gauges with qualifying orders of $99. Shop Gauges at Summit Racing.
Earl's Performance AT915106ERL Earl's Performance Couplers | Summit Racing
Free Shipping - Earl's Performance Couplers with qualifying orders of $99. Shop Fittings and Adapters at Summit Racing.
Fragola Performance Systems 893005-BL Fragola Performance Systems AN to Tube Adapter Fittings | Summit Racing
Free Shipping - Fragola Performance Systems AN to Tube Adapter Fittings with qualifying orders of $99. Shop Fittings and Adapters at Summit Racing.
