I'm installing new master cylinder AND all 4 wheel cylinders. The old fluid is brownish/orange.I would like to get ALL of the old fluid out. What procedure should I use?
When I replaced my Master Cylinder a few months back I swapped in a Dual Reservoir master for safety.
(I just don't trust those single reservoir "jelly jar" Masters, had one fail back in the 70's while driving)
I also changed the front drums out for Disc Brakes.
After Bench-Bleeding the Master and installing that, I gravity bleed the whole system one wheel at a time.
Took a while and and had to watch/top-off the fluid level in the master, but it was easy.
I hooked up a plastic hose to each bleeder valve (one at a time) and drained the fluid into a bottle.
Began the process with the wheel cylinder the furthest away, the Right Rear.
Good luck with your project!
