Yesterday my son and I tried to pull the 289 out of my '66 coupe. I have a load leveler bolted to four points, and the hoist attached. We disconnected all of the lines, hoses, wiring, etc. Removed the starter. Unbolted the trans. Got both engine mounts taken apart so they're not hanging us up. I'm not in the mood to spend a bunch of money on a transmission jack, and my motorcycle jack won't slide under the car far enough, so I cut a couple pieces of 2x12 long enough to fit under the transmission oil pan to support it.
The engine is free, and we managed to get about 1/2" or so separation between the block and the transmission, but for some reason I simply cannot get the engine and transmission apart any further, and can't get the engine out. We've tried various combinations of height and angle on the engine. I tried lowering it so the tranny is resting on the blocks, then tried moving the load leveler pivot point forward and back to see if it's just binding. Nothing seems to make a difference.
I've never done this before, so I'm unsure of how to proceed. I was under the impression that there's just a splined shaft connection between the engine and the transmission, but I don't want to resort to a 4' crowbar and break or bend something. How hard should this be to get the two un-mated so we can pull the engine out?
