21 - 40 of 139 Posts
Wanted:
Already posted in the Want section but thought I would try here to:
car is a 68cpe.
Looking for a front frame rail from the steering box to the toe board
-OR-
A repo section of the same..
cutout and pickup possible.
E-mail me at [email protected]
How do you change the title nowadays?
Anyway, looking for a set of leaf spring shackles, bushings, nuts, for the rear and the bushings and bolts and nuts for the front. Need them to be usuable but inexpensive.
I have to put some under my car when I go to get it in Ca in about 3 weeks. I am towing it on the rear wheels so they do need to be on the car.
All that is there right now are some cheap aftermarket lifting shackles and some bolts. No bushings at all. The springs are good, so I don't want to ruin them, not to mention the safety concerns of towing it this way.
Cheap but usuable is what I need. If I stay with leaf springs, I will be buying the more hefty version later on, but cash is a problem right now.
Let me know if you have anything.
Of course, if you happen to have a trailer you would like to rent out for about 2 weeks I wouldn't need the parts. :rofl:
Thanks,
Russ
For sale Shower Stall
This is new never been install shower inclosure 4 piece set floor and three walls. bad news is there is some damage to the large wall with the shelves on it cracked and broken. this is a sterling(kolher) set. It has to go because I need room in the garage for the Mustang.
thanks
phill
Mason ,Ohio
513-600-7678
here are the pics. I still need to take a pic of the damage to the back wall shelf area . It hard get that pic because it is still in a box.
http://img01.picoodle.com/img/img01/6/12/1/f_bath1i_c4d7m_193677f8.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath2i_c4d7m_072c2511.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath3i_c4d7m_50c032ca.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath4i_c4d7m_f3e00f54.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath5i_c4d7m_ed87db54.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath6i_c4d7m_f642bbd7.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath7i_c4d7m_b0ae65f9.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath8i_c4d7m_759ea271.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_bath9i_c4d7m_febb3627.jpg
For Sale: KILN
i have a kiln for sale or trade make offer. it must go! it is about 4 high by 3' round. 3 sections to it. controls on the side. not sure of the condition no way to test it . 22o volt.
call
513-600-7678
Mason , Oh
Phill
http://img01.picoodle.com/img/img01/6/12/1/f_kiln1i_c4d7m_44702c1b.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln2i_c4d7m_7168568d.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln3i_c4d7m_84f279b4.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln4i_c4d7m_0408a302.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln5i_c4d7m_971fb9b1.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln6i_c4d7m_bd32dedc.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln7i_c4d7m_63a484e6.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln8i_c4d7m_d704edd6.jpg
http://img01.picoodle.com/img/img01/6/12/1/f_kiln9i_c4d7m_25c3e640.jpg
Set of four '01-'04 Bullitt Mustang wheels and tires.
Two wheels have Nitto 555R's on them - all four are 245 55 17 (fronts are about ready to be replaced). This is the 5.72" bs wheel that requires 1" spacers to fit a '65-66 car (not sure about other years) - Here are a couple quick pictures, I can provide more if needed. PT me, Dan.
p.s. the only reason I'm not using these is that my DD is about dead and I'll need to replace it soon! ($$)
67-73 Global West suspension new, reduced prices
Parts in Dayton, Ohio
My friend James decided to part out his 68 Stang to recoupe some of his investment. He came by to visit for Christmas and brought some parts out here. If this stuff would fit on my car I'd buy it. I'm not selling these to make any profit, and I'm not getting anything from this, just helping a friend out. He's offering them at a slight prorated price to try and sell them to someone that will enjoy them. I will try to get pictures for the parts posted up soon.
Global West parts: NEW, some have dings from handling, bolted on but not used, inspect for yourself.
MNR-73 67-73 Mustang tubular upper control arms $580
TBF-7 68-73 Mustang tubular lower control arms $370
S-28 67-70 Mustang Competition 1" drop coils $125
SRB-5 Racing Rubber Strut Rod bushings $35
Adco 1 1/8 Front Sway Bar 67-70 w/zerx bushings $125
New in box, passenger head light bucket 67-68 $120
new 65-68headliner blk (w/ free new headliner padding) $25
window felts (belt line seals) 67-68 $45
Bart
I am looking for a set of 429/460 DOVE heads or older. Either rebuilt or in Very good ready to bolt on condition for not "crazy money" I want to replace the D3 heads that are on FBD.
Send me a PM on VMF
TFOB
Found a set for $400 Completely rebuilt!
Discussion Starter #29
Brand new Ford Racing 351 Windsor for sale. This engine has never been fired.
http://a.im.craigslist.org/ER/2H/r1uJVerKYtsFdANaf11lVHhuEoAl.jpg
The specs are below:
5.8L/351 cubic inch – 4V
250 HP @ 3800 RPM
350 ft./lbs. @ 3300 RPM
8.5:1 compression ratio
Includes Ford Racing dual plane 4V aluminum intake, Ford Racing tall polished aluminum valve covers M-6582-E302P, V-belt standard rotation mid-1970s style cast iron water pump with left-hand inlet, aluminum timing chain cover with fuel pump mount, fuel pump block off and eccentric, E5AE-6090-CA cylinder heads without thermactor air passages, F4TR-6380-AA HD truck manual transmission flywheel, high-torque flat tappet cam E7JE-6250-AA, full sump oil pan, Duraspark distributor and coil, spark plug wires, block is hydraulic roller cam compatible
$2,500 firm, pick up only (Rochester Hills, MI).
My cell # is (248) 703-6875
Looking for the following for a 68 project: Repost from Wanted section:
-source for rotor only without hub 68-73
-drivers deluxe black comfortweave seatback original (code 5A)
-HAVEremote drivers side mirror with nice chrome
-disc brake dust shields.
-68 3/8 gas tank sending unit working
-Original rear passemger fender apron
-all 4 splash sheilds
-15/16 original away bar
I am sure there is more, and I will add it once I think of it. [email protected] with pricing & condition of part.
For Sale: 302 Mexican block, casting #D1MZ-AA, hasn't been bored, asking $300 or best offer.
for sale 1968 -69 mustang /torino factory chrome steel wheels complete with center caps and rings.excelent white letter radial tires.rims are nice for a driver.first $350. thanks mark
Selling my '68 mustang coupe. 289, v8, sprint "B", Eastertime Coral. Car comes with new front seat upholstery, driver side cushion, passenger door panel, carpet, original steering wheel, and various tune up supplies...spark plugs, belts etc. Asking $8,500.00.
Crunch GTR speakers (round). Brand new in box. 5 1/4" coax. They will not fit. just trying to get something out of them. $30.00
Robin
