tsk tsk tsk...thats why ya gotta read and ask a butt load of questions like i do and u end up bugging everyone on the forum! lol j\k about that last part ::
this is from Ron Morris JR's site....
94-95 MUSTANG 5.0 ENGINES
This is a good engine, computer and wiring system for an EFI conversion. It uses a 2 speed electric cooling fan, an electronically controlled automatic transmission (AODE) and has data link capabilities.
If you are installing this engine into an early Mustang, the timing cover does not have a place to drill for relocating the oil dipstick tube. The timing cover that comes on the 94-95 Mustangs is shorter than 93 an earlier timing covers and has it own water pump and accessory brackets. If you decide to change the timing cover you will also have to get different accessories and brackets. If you plan to run air conditioning, you will have clearance problems using the stock 94-95 brackets and a/c compressor. The compressor will interfere with the shock tower.
This engine uses an external EGR tube and since the factory headers will not work in early Mustangs or Broncos, it will require some fabrication to tie this tube into your headers or exhaust system. If you do not want to run the EGR system it can be removed with the RMP EGR Eliminator kit.
This engine also has a different distributor than the 86-93 engines, it uses what ford calls a closed bowl distributor and a remotely mounted TFI ignition module.
The main reason for the horsepower decrease in the 94-95 engines (215 HP) compared to the 86-93 engines (225 HP) is that Ford had to go to the 89-93 T-bird intake manifold to clear the reduced hood clearance on the new body style Mustang. This new lower intake manifold has smaller runners and a smaller plenum area causing the reduction in power.
Ron Morris Performance
