Brain fart! They are back!!! I will sneak the camera today and post a new one!!! hehehe.
Also, here is a pic of where I installed the headlight relays. the radiator support/inner fender area is to the right, on the left is the edge of the fender. If you look closely, you can see the Brady labeller labels I made for the relays. That way, when I go back to troubleshoot them in 35 years, I will know who is who.
http://albums.photopoint.com/j/View?u=1571478&a=12409371&p=45514478&Sequence=0.jpg
http://albums.photopoint.com/j/View?u=1571478&a=12409371&p=45488890&Sequence=0.jpg
Very clean-looking installation, Steve. Did you have to drill any new holes? What kind of lights are the relays supporting?
I hope to see the car at Knotts and get a closer look!
Glenn Morgan: 66 GT V-Burgundy Fastback 351w+toploader+9 in. TracLoc. Started out as a rusted-out Chicago-area crusher. After sacrificing a solid 66 coupe for its sheetmetal sub-assemblies, I have one solid (and expensive) work in progress!
I drilled four holes. One for each relay. I also have a horn and switched 12 volt accessory relay mounted on the rats nest / starter solenoid area that I can't seem to get 'clean'. I installed a jam nut in each relay mount. I am running the Tri-Bar lamps that MUSTANGS PLUS sells. They are really bright and look awesome.
Looks good. I'm planning on doing the same shortly.
Did you splice it in to your harness or did you make it plug into your harness?
[color:blue]
1967 Acapulco Blue coupe
302 4V, C4, 9" 3.25:1
Torq-Thrust "D" 225-60-14
1968 PDB, Corbeau
LeCarra, Alpine in-dash CD
http://www.geocities.com/mlnielsen_67/index.htm
WEBSITE UPDATED 3/25/01
</font color=blue>
