Will a set of 14x7 magnum 500 wheels fit over a granada spindle swap? I have heard of both 10" and 11" brakes, will these wheels fit over both sizes?
I had to grind my calipers down somewhat to make the magnums fit. I used masking tape on the caliper, installed the wheel to see where it was rubbing and started grinding in stages, retesting the fit until there was enough clearance.
Discussion Starter · #4 ·
What size tires did you have on to cause interference. Was it rubing on the the ball joint?
I have a set of 4 - 14 x 6 1/2" magnum 500's and they clear fine. I have 2 - 14 x 7's and they do rub a little in front. No problem with either with regard to the caliper
