Last year I finished my Granada disk brake conversion. At that time i scoured the archives looking for master cylinder recommendations. I finally settled on a MC from an early 70's F250. It turned out that the push rod for this MC is apparently too short as the pedal does not return to its fully upright position after it is pressed. It is bad enough that the brake lights will often stay on unless I lift up on the pedal after braking. I either need to find an adjustable pushrod or a more appropriate MC. I am leaning toward the pushrod because I dont want to have to worry about a new one having different sized fittings. Trouble is I don't know where to find an adjustable rod. Also after I do find one is it possible to remove the existing pushrod from the MC. There is a locking clip holding it in place.
