also, what year granada do i use?
why cant i use the master cylinder that i already have in my 67? its a dual bowlThe year Granada is the mid to late 70s. You will also need Granada spindles, You can't just buy new calipers, pads, etc and bolt them on your car. I don't think you'll find Granada spindles in the Oreilly parts catalog.
Alternatively you could also just go with the stock 67 Mustang disc brakes too.
Look at CSRP or Chockostang for complete kits. This may bet the best way to go.
I suggest going with manual disc brakes with either a Maverick or Ranger 15/16 bore master cylinder. I have used both and like the Ranger one.
how much do these kits usually go for? and can i get them in the 400-500 range?You have a 67, that means the factory ford disc brakes will bolt to your Spindle. Call chockostangclassicmustang.com and he'll sell you what you need to do the swap. The Grenada swap was a great option when we had little to no other option. Now, not so much.
Pm @CHOCKhow much do these kits usually go for? and can i get them in the 400-500 range?
what does a rebuild of the drum brakes include? i already have new brake shoes and hardware that i need to put on. I was just looking at my disc brake options so i have an ideaI commend you on your desire to upgrade. But honestly at your age and price range, a good rebuild of the drum brakes will get you down the road and stopping safely. Make it safe, make it reliable, then make it fun.
A complete rebuild would include drums, wheel cylinders, adjusters and springs. All that stuff gets completely shot after 50+ years.what does a rebuild of the drum brakes include? i already have new brake shoes and hardware that i need to put on. I was just looking at my disc brake options so i have an idea
the front what? disc? or drums?Drums are probably ok. I replaced the steel brake lines, master cylinder, hoses, shoes, hardware, bearings and had new axle bearings installed for under $300, that included new rear drums.
With less than 100 miles on the fronts I tore the car apart for an engine swap and went to discs at the same time.
Zackary, I'm an hour south of Atlanta, if you were closer I would give you the fronts. All they need is to be installed and bled.
Master cylinder for Disk/drum and Drum /Drum are different. Disk brakes need larger amounts of fluid and thus have larger reservoirs. A dual drum MC has two reservoirs te same size.why cant i use the master cylinder that i already have in my 67? its a dual bowl
I’m another no vote for Granada. Much better complete options available. I did 67’ Kelsey Hayes CSRP swap manual kit on my existing V8 spindles. Power brakes are much harder to install and really not necessary in these cars. $650 for a truly complete kit with good instructions.So, my 1967 mustang has drum brakes all the way around since its just a base 6 cyl car. I've heard of how people do granada disc brake swaps. At the time i didnt think much of it because i just thought to myself "where the **** am i supposed to get a granada?" but today i had the great realization that i work at O'reillys and order brand new granada brakes and get my discount and do a really cheap disc brake conversion on my pony. BUT I still need yall's help. what are ALLLLL the parts i need to change out my drums with granada disc? i already priced the rotors, pads, and calipers as you can see in this picture here.
