On a 66 you need the outer tie rod ends and the sleeves. Although the sleeves look like they will work because they are threaded the same size, you will not be able to get the car into any sort of alignment if you don't get the granada sleeves.
The outer ends are actually angled differently. It appears a though the bushing is intended for a Versailles swap, not a Granada. :(
Unless there is a difference in the ends for power steering. I don;t have PS, but when I did my swap the shape was a problem. I could not make the ends line up on the new spindles (even loosely without bushings).
