1 - 2 of 2 Posts
I did some searching on here and found some useful information, but nothing that seemed to answer my issue.
I have a Grant 3294 hub adapter for my 67 Mustang, and when it is installed it appears to ground out against the emergency flasher switch. I've compared it side by side with the factory steering wheel, and the factor wheel seems to have a longer "spacer" between the end of the wheel and where the horn contact ring lines up.
I went to a local mustang shop and talked to them about it. Said that they don't use grant wheels because of the problems, etc... I've already spent the money on this wheel, I'm hoping I can use it.
Has anyone dealt with the same problem?
thanks!
I believe am having the same problem. Did you ever figure out a solution?
1 - 2 of 2 Posts
