After having installed my fog lights, power windows, power locks and alarm (much thanks to various VMF'ers), I am now left with 7 different ground wires underneath the dash.
Seeing that I'm a complete electrical newbie, I was wondering how I should ground them underneath the dash? Can I ground them all in the same place - or do the different wires need separate spots?
:)you can ground them all at the same spot if they are long enough but make sure it is a ground. ::
Cool - yeah, I'm pretty sure the ground is good seeing that it was the original location for the single ground wire I used to have down there :)
Can just use a multimeter with the positive end to a hot wire and the neg. wire to the ground to check if the ground is good. I would suggest sanding the direct contact where the ground to make sure you get a good connection.
