On my 65 289, I have the ground cable running from the battery to the engine block. It is grounded at the same location as the alt ground.
The second ground is from the right cylinder head to the firewall. That ground cable is pretty small and grounds at one of the screws that holds the brake line to the firewall.
I dont think that second ground is adequate.
Im thinking about running a third ground from the block to one of the sway bar bolts. That doesnt require any holes to be drilled.
Will that do the job, or do I need to increase the size of the ground wire from the head to the firewall?
I have a new alt harness and a new set of battery cables.
