I have a chance at a engine with gt40 heads, 93 302 roller from a explorer. Does anybody know the CC size of these and would they be OK on a 65 289 ? Thanks
1967 Mustang Convertible
They are about 61-64cc. I had them on an 89 Mustang and I was getting about 240RWHP vs the stock 190RWHP. They will outflow your heads but will probably drop your compression pretty low. Is your 65 the A code or C code engine?
Hmmmm, flow VS. compression.
EZ answer if you use the entire engine.
If you're going to have them rebuilt look into how much they can be milled down beforehand.
Those would drop you to around 8.2 compression. I wouldn't do it without replacing the pistons at the same time so you could use them to adjust your compression ratio back up. For instance KB116 pistons would get you up to about 8.9:1 There's a pretty good chance the valves would hit the stock pistons anyway, as stock c-code pistons didn't have valve reliefs (at least mine didn't) They just had a little bit of a dish cut out.
Or...as others have said...use the whole engine.
Phil
