Hi All, I'm new at this. I just got my 1968 mustang and i'm having problems with it. I had to replace the spark plug wires due to one plug touching the headers and burning the boot. The car ran smooth for a while and then it started idling rough. I'm also having a hard time starting it after a few miles of driving. I had to wait for about 30 minutes before it fires up again. The last time it happened, my battery died for trying to crank it a few times. It started when I jumped it. I'm not sure if it's the battery, which I had it charged, starter, spark plug wires or spark plugs, carburator, distributor cap and rotor. Please advice :(
It could be a number of things. If only when warm, make sure your choke is operating correctly. It should be open when warm, closed when cold.
Check that the wires to your starter aren't sitting on the headers or something. Resistance increases with temperature.
Sounds like the engine is turning over so it should be more of a fuel related issue. Search vapor lock, fuel pump defective or as mentioned before choke plate but it sounds more like vapor lock
Discussion Starter · #5 ·
Thank you all for the help. I'll check all the suggestions tonight and keep you updated. It's great to get suggestions on this.
Discussion Starter · #6 ·
66 6,
How do i check for fuel vapor lock and how will I go about fixing it? Also, I noticed that the choke plate is open even before I start the engine. Is this normal?
