I have a strange starting problem. My 68 Mustang 302 starts great when the car is cold but if I try to start in once it's warm/hot it turns over very slow as if the battery is dead. The battery & starter are both new and the battery has a full charge. Any ideas what might be causing this?
Sounds like the classic case: You starter is getting too hot due to header/engine heat.... Heat cause a resistance and the more heat you have the greater the resistance to electricity. Did you get a "high quality" starter? Is it close to your headers?
See my 69 convertible and the VMF parking lot at: http://www.geocities.com/Bishir1/FrontPage.html
http://www.jps.net/binay/webdocs/frontside_sig01.JPG
I have noticed this in my 68 as well, happening less than 1 time in ten when warm, though. It will usually start up fine if I turn the key again. I'm guessing a loose connection somewhere or a suspect starter relay...
68 coupe - Soon to be daily driver (I hope!)
My 69 302 does the same thing. The starter is close to my headers and heats up causing greater resistance. My battery is relatively fresh but, when warm, the car will occasionally crank slowly. Anyone tried one of the smaller starters advertised in the racing equipment catalogs?
When all else fails, THOROUGHLY clean all grounds on engine. Have had this cure two vehicles of this illness. They would probably still have the problem if my dad didn't keep telling me to do this. i KNEW that was not the problem
