Recently and in the past, there has been the question on which box is power, manual, or GT. I had some independent references that claimed one thing while Mustangs Unlimited and other vendor catalogs indicated just the opposite. Assuming Ford knew what is correct, I looked in the 1966 Ford shop manual and found the following on page 31:
HCC-AT Manual, 19:1, 4 5/8 Steering wheel turns, 4-5 in-lbs worm bearing preload, 9-10 in-lbs total preload
HCC-AX Special Manual, 16:1 3 3/4 Steering wheel turns, 4-5 in-lbs worm bearing preload, 9-10 in-lbs total preload
HCC-AW Power, 16:1, 3 3/4 Steering wheel turns, 3-4 in-lbs worm bearing preload, 8-9 in-lbs total preload
After reading these specs, I wonder if Ford set the 16:1 boxes up differently (bearing preloads) and then tagged them as either AX or AW? If so, then if we put an AW box in a manual setup, should we adjust the preloads to the AX box specs?????
66 Fastback
85 GT Hatchback
67 Coupe
82 GT Hatchback
66 Fastback
85 GT Hatchback
67 Coupe
82 GT Hatchback
