·Stainless steel from the headers back makes sense. You can also pick up stainless mufflers from a few different sources. They cost more, but you'll never need to replace them unless you physically damage the set-up. No coatings necessary on the pipes or mufflers. I had a buddy who put a 2-1/2" set up on his (shhh!) Camaro, looks good and no maintenance in 10 years.
Don't think that you can find stainless headers. Best bet for longevity here is to order up the headers (or send in your current headers) for a coating by someone like Jet Hot, or the like. The do it yourself jobs I've seen have not compared.
A word of caution: be careful when you install your coated headers. If you rub them on your shop floor you can damage the coating.
On the flip side - I put on Hooker Headers without further coating, the black paint peeled almost immediately. In retrospect do I care? Not really - I still love the sound and the power they bring to the car.
Pipe diameter. If you are running a 289, anything bigger than 2-1/2" is going to hurt your low end performance. The original dealer installed dual setup on my A-code motor had 2" pipes. I went to 2-1/2" because I also opened up the intake side of the motor.
Finally - don't forget to get either an H-pipe or an X-pipe. Added performance and better sound.
Good luck.
Good luck.
