I'm installing my headers. What side of the gasket goes toward the block? The foil faced side or the non-foil faced side?
TIA
Also, should I use any type of sealant?
If one side has a metallic surface it's probably there to protect against heat. The heat is coming from the cylinder head so I would guess that would be the side to face the exhaust ports. Besides, if you've ever had to scrape a header gasket off a cylinder head before :: you'll appreciate the metal face.
I always thought the foil went against the exhaust manifolds or headers. I've seen my headers glow red hot so I think that's the hotter side. The heads are liquid cooled so I don't think they get as hot.
