1 - 9 of 9 Posts
I just pulled the factory exhaust man. from my 65 289 2V.
I am putting a 4v intake "stock" and a 4v carb.
My questions: Headers and what brand for durability and performance. What brand and CFM of carb? Lastly is there a
better manifold on the market. This car is a sunday driver.
I run a holley 600 cfm with vacuum secondaries and Hedman long tube headers. I wouldnt go any bigger that a 600 cfm if your keeping it semi stock. I have a mild 302 and it works nicely. The prob with Hedman and Hooker is ground clearance, I have only 3". For a sunday driver this shouldnt be a prob.
Alot of people on this forum recommend Ford Powertrain headers, I have never used them but apparantly they are pretty good, and the ground clearance isnt an issue (not certain).
http://www.fordpowertrain.com/
Oh and last but not least pay the extra money to get it jet coated, i didnt on mine, i just painted it and they look horrible already. And its only been 8 months on the car. But it is a daily driver...
Lotta headers available for SBF. I will say I wasnt impressed with hedman's SBF hedders; the collectors angle inward, so making a homemade exhaust is a little more trouble. They also seemed to go under the tranny pan (no thank you!!)
Most aftermarket intakes are considerably better than stock 4bbl intakes.
Out of all that I have installed, the Hooker Super Comps are the best fit on a 289 or 302. Get the jet coating. My headers are 1997 vintage with 30,000 miles on them and they look brand new.
Gone but never forgetten
The best I've seen yet for fitment on a '65/'66 (or '67-'70 for that matter) is the Hooker Comps. The hooker Super Comps probably run a close second, but you'll gain more ground clearance with the regular comps, because they tuck closer to the floor pans.
For a stock to mild 289/302, I'd highly recommend the Edelbrock Performer intake. The weight difference alone is justification for the $110 or so you'll spend on the intake.
I agree with the previous poster about forking out the extra $ for ceramic coating. It is WELL worth the money!
MustangSteve,
How do the Hooker SuperComps fit on a 65 289 with factory 4 speed?
Thanks for your time,
John Thomas
Yes, they fit quite well, but I can assure you the clutch linkage Z-bar will test your patience!!! Once on, they clear everything, and give excellent starter clearance. On the car that I put them on with a toploader, the car was later converted to T5 with no problems, but the original clutch linkage was also reused. (I will NEVER do THAT again!!!) :p
Do you know if the Hooker Comps fit the same as the Super Comps?
Thanks again,
John Thomas
1 - 9 of 9 Posts
