Nice. I run a similar buss bar. I used 2 waterproof relay holders without a cover. I like the box with the cover. Perfect if you want to do headlights, horn, and fan relay!
<style></style>
<style></style>
Not an embarrassing question. Relay's take the brunt of the amperage, that would, otherwise, be passed on to a far weaker switch. In the case of the Mustangs, the light switch takes the brunt. So, by adding "Relays" we reduce the effort taken on by the light switch, plus, provide a far better voltage path to the headlights. This results in a "brighter' old style bulb? Many have added more modern bulbs, as an alternative.I'm almost embarrassed to ask, but what is the advantage of installing relays to headlights, horn, etc?
I'll take a look at my wiring and get back later.....BTW, I do recall the Dimmer needed a attention, just don't recall the details.I need to add something to this discussion. Does anyone recall where the wires from the dimmer switch go? Do they go straight to the main plug or is there a junction before. I was thinking when I rewired that the low and high beam wires went straight to the main plug. They then went on to the headlights. Please correct if I’m wrong.
Yeah!Final update on my high beam problem. I think I told you that if something could be screwed up I would do it. Well in tracing the wires I found the main plug in the dash was loose. I unplugged and readjusted and, what do you know. High beams!!! Thank you for all your help.
A nice drawing, but I'm wondering if you could you post a larger and/or higher resolution version of the image. Thanks.I don't know if this helps OP. But it may be useful for anyone considering DIY.
Just to let you and everyone considering this, the 12$ Chinese from fleabay and the 30-40$ ones from CJPP et all look exactly the same. I put the cheapie on my 66. Worked great, just had to wait 3 weeks for it! It can be easily modified if you want to clean it up and integrate it as @DonP has posted. I just plug and played the supplied plugs, and hid everything.Good thread!
I’ll be tackling this soon now that I’m back on the road.
