i posted this a day or so ago
"my headlights in my (70 mach) after a short while will blink on and off... i put in a new switch in and still no dice... :0( all the other lights work fine including the sport lights in the grill..... there is a larger wire (black with and orange stripe) that goes into the headlight switch that gets pretty hot....... the lights will stay on longer if i only have the low beam on...,,, does the head light swicth have a ground that i've missed?..... any one have any idea what i can check?......i'm hoping to have her back on the road early next week..... thanks jace"
i got a few replies to replace the dimmer switch and i did... the lights stay on a little longer but still blinking . does the dimmer switch ground to the floor of the car? my car has had floors put in and the bolt holding the dimmer switch are a little loose..... could i try a little larger bolts?...... the black and orange wire is still getting hot........ also i have to take the battery cable off at night or when then the car set awhile or my battery will go dead.. so i know i have a short somewhere... think the problem is connected to each other?....... thanks for anyhelp on this jace
