Hello all, I have a 65 two speed blower motor which runs perfectly and a NOISEY 66 three speed blower motor which is currently installed on my 66. In lieu of re-switching and rewiring my 66 and installing the 2 speed blower, can I take necessary parts from the 65 two speed and refurbish the 66 three speed motor? Are the bushings/bearings interchangeable?
A new motor is $20 from RockAuto.
The 2-speed and 3-speed motors are completely different. The 2-speed is two circuits inside a single case. The three speed is actually a plain single-circuit motor, controlled through resistors to provide variable speed.
The $20 VDO from Rock Auto is very close, only the wires give it away. If you want exact, get the ACP repro motor.
Typically, these motor have a bearing on the "fan end" and a bronze bushing on the "commutator end". Either can "sing" if the lost lubrication. I've found many times these small DC motors can be disassembled and the bearing and/or bushing replaced. Sometimes all it takes is a little electric motor grease and a hypodermic needle.
As far as the '65 vs '66 motors... hypothetically speaking I don't see why you COULDN'T use the entire '65 motor by leaving the wire to the low-speed winding unattached (and capped) and wiring the high-speed wire to hot and the ground-side wire back to the blower motor resistor. It's hard to say whether the original 2-speed motor has the durability to run with its voltage lowered but there's one way to find out....
I'd examine rebuilding the original '66 motor first, though.
THX for the input. ACP looks good.
