i'm working on an early 66. the heater blower motor is shot. it is a 3-wire unit. all the replacements i find that have 3 wires do not have the mounting plate attached. i know i can reuse the squirrel cage but what do i do about the mounting plate. looks like it is crimped to the motor..........i'm stuck..........thanks
It should be bolted.
Do you have the fan off?
Discussion Starter #5 (Edited)
no, not yet. i found the nuts. got them loosened a bit and have the allen screw out but the cage is stuck tite to the shaft. know of an easy way to get it loose w/o mangling the cage up ??
