What type of helmet do I need for going on a road course? Where to buy one? How much do thet cost?
Most clubs specify a Snell SA2000 rated helmet. I recommend not buying a really expensive helmet, the helmet will expire in 5 years...
I bought my last helmet from Racers Wholesale in Roswell, GA.
About $150.
Here's a copy of an e-mail from a couple years ago that may help...the ratings have changed (SA2000 now vs SA95 then but the info is still valid):
Hi August,
<< What are the differences between a Snell rated motorcycle helmet vs.
a
car helmet of the same rating?
Good Question!
The automotive helmets (SA95) are different from motorcycle helmets
(M95)
in two important ways. First, SA helmets are designed to absorb
multiple
impacts whereas M helmets are designed to absorb one heavy impact. In a
serious car crash a drivers head will experience a series of minor hits
while
the car comes to a stop. Often the drivers helmet will strike the same
location several times. For that reason it is important that the helmet
remain intact until the car comes to rest. SA helmets are superior for
this
application.
The second important difference between the two types of helmets is
that
SA helmets are more fire resistant than M helmets. The liner in SA
helmets if
made out of Nomex. Even if the fire does not reach your head, the heat
generated by a fire can melt the liner of a motorcycle helmet. The
residues
from the liner will then bond to your skin and be uncomfortable to say
the
least. Basically the SA helmet will buy you a little more time to get
out of
you car in the event of a fire.
Since it's inception TCC has not had any drivers involved in a
vechicle
fire. So to this point we probably could have gotten away with only
requiring
M rated helmets. However since the safer helmets are available at a
reasonable cost, that is what we require. As a driver it is comforting
to
know that you have done as much as you can to protect yourself while on
the
track. It lets you concentrate on more important things like passing
the car
in front of you!
I hope I have answered your question. Please don't hesitate to write
back
if you have any more questions concerning road racing or Touring Car
Club.
Andy Hope,
Sent you a PM
