I need to take an ignition cylinder out of a non tilt column and put it in a tilt column I bought. I cant figure out how to get the cylinder out! Any helpful tips would be greatly appreciated!
Thanks in advance ::
You'll see a little silver dot at the base of the lock cylinder area. The key has to be turned and the button held in and suddenly the lock cylinder pops out.
Also, there is an interconnect between the reverse lockout ring and the ignition cylinder (surprise surprise). If the lockout ring isn't turned to the right position, you can't rotate the cylinder enough to get it to release.
Carl
Got it!
Thanks ::
