1 - 2 of 2 Posts
I have a '73 mustang that has the vacuum controls for the Heat and A/C dampers. I pulled the engine out for a rebuild and, when I put it all back together, I didn't make a note of where the two small vacuum lines get connected. I just hooked them both up to the vacuum system and now the controls work but I have a leaky noise in the dash when I put it on defrost. Can anyone tell me the correct place for these lines?
One line goes to the vacuum canister on the passenger side rear apron, the other goes to the vacuum operated water shut off valve in line with your heater hose.
1 - 2 of 2 Posts
