I need to know what the cylinders are numbered on a 76 302 and what the firing sequence is so that I can hook up my spark plug lines
1969 Mach 1
1976 Cobra II
Cyl arrangement:( Pass side1-2-3-4) ( Driver side 5-6-7-8)
FO 1-5-4-2-6-3-7-8
Every day is a holiday if you love your job.
Current projects: 65 Fastback, 68 Coupe Oval Track Racer, 64 Galaxie 500 XL, 54 F-100 Pickup
http://images.honesty.com/imagedata/h/030/44/30304480.jpg
remember to put the wire on the cap in a counter clockwise direction in the firing order.
I found out that the hard way! :)
Michael Wigton
1964.5 Mustang Convertible
On my 1968 the firing order is stamped on my manifold. You might check there on yours, don't know about you v-8'rs though. Maybe Iacoca just liked us IL6'rs better;)
1968 Coupe, 6cyl Std, Bench Seat. Driven through 10 years of College.
So is the #5 cylinder the one closest to the front of the motor or most distant? I guess 1,2,3,4 are the cylinders from front of car to back ... so drivers side is 5,6,7,8 starting from the front as well or does it go clockwise?
1969 Mach 1
1976 Cobra II
