In my Deathtrap Trans Am Build (1970 Mustang Fastback Restomod), I plan on building a high revving 302 that puts out around 500-525hp (I'd like 460 wheel) and has 10.5:1 compression. The max rpm goal is 8k. I will be using a tremec 6 spd so I won't be shifting over 7,200. I just want the extra rpm for safe measure. If I can rev it to 6-7k and not have to worry about it splitting down the block, I'll be happy. I plan on using Holley efi. I've read that similar applications have used the Dart SHP 302, forged internally balanced crank, crank girdle, h-beam rods, flat top pistons, and a Victor Jr. Intake. What do I need for the top end to meet this goal and keep the engine reliable? I'd like to do what I can myself, but obviously machine work and porting will be done out of house. I know that the engine will be pricey, but I'd like to spend less rather than more (if something doesn't have to be billet, I won't get it in billet!) This engine build will be in a few years so I'm trying to spend the time now to figure everything out to build this as best as possible. Thanks for the help in advance.
What’s your goal for the car?
It’s your car, so ultimately if you want to have an 8k rpm 525hp 302 just to go get ice cream, more power to you. (Not saying that’s what you’ll use the car for, just a point that you haven’t stated it)
Recommend that what engine you build should match your intended use. If you plan to road race your “Deathtrap Trans Am” (love the name), then what you’re looking for is appropriate. Some of your parameters may need to change (as both patrick and jdub stated), but otherwise makes sense. And, if you’re planning to road race, checking with the rule book of the sanctioning body governing the races you want to enter. A complete waste to build a motor (or any part of the car) that isn’t race legal.
If you’re goal is more towards canyon carving or autocross… perhaps consider a stroker motor. 500hp becomes a lot more affordable and reliable with more cubes, and a little less rpm. A supercharger is also a nice option.
But if you’re thinking “nah bro, I want my motor to scream all day everyday!” Then hell yes, open that wallet super wide, sell a kidney, and let us help you spend! $$$$$$ maybe look at a reputable engine builder and have them put together a bad a$$ combo for you like this
Doesn’t quite meet your RPM, but obliterates your power goal. But it’s also a stroker, so there’s that.
Sent from the interwebs... where else?
