Has anyone had any luck finding 2speed Wiper Switches for a 73?? I've called all over and no luck, my local Ford dealership laughed at me :( Anyone able to point me in the right direction? Thanks
Kyle
I've seen them come up regularly on ebay. Ohio Mustang Parts/Supply is an ebay seller that has quite a bit of original used parts. You might check there.
Good luck!
Sir I have a 71 mach1 parts car that I just got home. I will check it this afternoon when I finish all that SWMBO has for me to do today.I will let you know what switch is in it ::
Discussion Starter · #4 ·
That would be great, thank you so much. I finally get my car together and I can't pass inpection because the housing on my switch cracked :( So close i can taste it
Thanks Again,
Kyle
I've got several good used if nanceb can't help you out...
I have a good used one. Send me your address and I will mail it to you. E-mail me at [email protected]
1972 Mach 1 351CJ-C6-9" 4.11 Detroit Locker
I got finished with SWMBOs list the mach1 has the switch But looks like there is several here .If I can help let any of use know. ::
