help me building a 331 stroker out of a 289
6556 Views 87 Replies 16 Participants Last post by  Christof 1966 coupe
I think i know what to do with my 289 block (it needs a complete overhaul)
So i'm thinking of a 331 stroker .
Next week i will be bringing the 289 block to a rebuild shop to see if a 0.040 overbore is enough for getting good cilinder walls (now it has 0.030 overbore)
so i can choose the right strokerkit.
I'm aiming between 300 to 350 hp at the crank (so my rebuild t5 WC can handle it).
because i'm not getting the max hp out of this 331 i don't have to buy the best and most expensive parts that i can get (i live in Belgium and i have to pay 33 percent more over all the parts and shipping costs
i have surched on websites for pricing on stroker kits and summit gives me the lowest shipping costs(other companies asking double or triplle the price as summit racing shipping costs)
now they have a
SCAT Engine Components 1-94055-040 - Scat Engine Rotating Assem. 1850 dollar included tax
with cast iron crank , Forged 4340 steel connection rod , plasmamoly rings and forged aluminum pistons.
it says it has a +11cc piston to head clearence.
If i put these heads on it (a 58cc flotek or 60cc blueprint or 62cc NKB from skip white performance on it ) how much static compression will it have and will it work fine?
we have gasoline E5 (ron 98)with 5 percent ethanol and E10 (ron95)with 10 percent ethanol. or the most expensive is ron 98 without ethanol.
Eagle Specialty Products 16022040 with 6.50cc pistons for 80 dollars less but its only avaiable at may 2022
Will the +11cc or +6.5cc make a huge difference and what should i buy ?
Thanks for helping
1 - 20 of 88 Posts
Here’s a good compression ratio calculator
Summit calculator
I have a lot going on at the moment, will post more later
The Eagle kit looks like it's a 347. Actually a little bigger because of the .040 bore. You'll need to know your deck clearance and gasket thickness to get a closer reading.
did i do this right? did i use the right deck clearence?
62cc heads is 9.14 is this enough or what cam max can i buy? a 282 comp cam?
is 58cc heads better?
See less See more
Yep, you did that right. .011 deck is a ‘close/good enough’ estimate, but that brings us to quench height (distance from piston crown to cylinder head). With your input numbers, you have .052 quench.
That’s a lot. The sweet spot for a steel rod street engine is closer to .040. You could get closer to that with a thinner head gasket, but at this point we do NOT know what the deck height is. Thus the estimate.
Camshafts. Ask ten guys, get ten different answers Lol
I‘ll just say that the Comp 282 grind is close to the ideal SBF camshaft for street use. It’s damn near perfect. In fact, it’s what I run
Arizona GT
Yes i can build the motor and after this i can choose a thickness of gasket . But i have allready felpro 0.040 in my garage.
Do you have a vid of youre car with 282 cam (what engine?)
If you're capping off the power due to the T5's inherent weakness, why not just leave it a 289? I recently put together a 289 with AFR165 heads and a good hydraulic flat tappet cam and this thing with a toploader and 3.50s in a '68 fastback with 225/60/15 radial T/As will incinerate tires from a stop without trying hard at all. This engine would absolutely blow up a T5 if you beat on it hard. It's in the low 300s horsepower and more torque, by butt dyno. So why spend the extra money on the stroker kit?
Reactions: 2
Arizona GT
Engine is very similar to what you’re after.
Fun little motor in a fun little car ;)
  • Love
Reactions: 5
Just a little bit of advice..... "Building a motor" involves much more than just picking pieces from a catalog or website and installing them. Selecting the wrong components can end up with you leaving a lot of potential performance "on the table" or, even worse, lead to premature mechanical failure. Unless you have a good understanding of engine theory or are assembling an engine to a previously proven set of parameters I would suggest buying a complete long-block assembly, most which come with a warranty of some kind.
Hint: Remember that the companies making these aftermarket components are in business to make money, and their advertising and marketing is developed around convincing you to purchase their product. Also, don't forget that what someone may claim about a product they purchased may, frequently, be more opinion-based than fact-based....especially if they spend a lot of money on it.... after all, who really wants to admit that they may a poor purchasing decision?
Reactions: 4
10
Christof I did what you are planning, in 2016 to my '68. I went for the Scat rotating assembly & Stroker kit # 1-94055BE with 0.030 over Icon Forged 9970 FHR pistons.
After the parts arrived I took the block & pistons to the machine shop, had the bores honed with clearance for forged pistons & the block zero decked.
With 0.039 compressed thickness Cometic MLS head gaskets I have a static CR of around 9.8:1.
Working the valves is a Lunati flat tappet camshaft # 10350702 with 1.6:1 Lunati roller rockers, & it is topped of with a pair of AFR Renegade 165 heads, RPM Air Gap Intake & a Summit 600 Carb.
It is a very peppy little engine & I am more than happy with the results of my work.
I am in Germany so more or less the same European Import BS applies here as you have in Belgium.
I'll tack on a few photos of the build if is of any help.
Cheers. Gaz.
Be sure to order the correct flexplate/flywheel with the kit as it is a balanced assembly.
See less See more
Reactions: 2
6
These pics were from a recent freshening up, about 2500 miles on it now.
I first built this motor about 20 years ago.
Automotive lighting Automotive tire Motor vehicle Wheel Tire
Automotive tire Automotive design Motor vehicle Vehicle Alloy wheel
Automotive tire Motor vehicle Automotive design Automotive exterior Office equipment
Motor vehicle Automotive tire Automotive design Engineering Machine
Automotive design Motor vehicle Engineering Gas Auto part
Automotive tire Automotive design Gas Engineering Audio equipment
See less See more
Reactions: 4
My young adult son doing the grunt work 😜
Workwear Automotive design Engineering Gas Service
See less See more
Reactions: 3
Scat crank is either cast steel or forged steel and not cast iron. You will probably need to add some dollars for the stroker kit install. You will need to get it balanced with your damper of choice and flywheel or flexplate. I didn't want to rely on what somebody at Scat might do for this. My shop didn't like the finish on my crank so they micro polished it "again". Would somebody at Scat done this? Not sure. As it was delivered it didn't look like it was micro polished at all.
Considering it was a stroker kit I also decided to pay my shop to balance and blueprint it which I believe was a wise decision. The forged rods are supposed to be a matched balanced set and one of mine was not. They did send me another rod that was closer but it still required a bit of grinding to match the rest. I made Scat(in this case) send me another rod. I also had one rod bushing that was deformed so I had to have Scat send me another one. I would have not known about these things if my shop had not balanced it in house.
See less See more
Reactions: 1
4
I vinegar thread my engine block because it was full of rust but now I see that there is a engine block piece missing where the cilindern sleeve is put in .
Do i have a problem ? Can ik just bore this sleeve and. Put a stroker in it for max 350hp?
If not I hope I can find a new block here in europe
See less See more
That‘s no problem at all, just some rust/scale, no need for a sleeve.
Run it 👍
Reactions: 1
Arizona.
The block has a sleeve in it . I think there is a part missing from the cast of the block and what you see is the sleeve
You'll have a reliable fun street motor with that 331. Don't worry about hurting your rebuilt T5. Unless you decide to make a habit of really hooking up (slicks etc..) that T5 will do just fine.
Reactions: 1
Arizona.
As long as it wasn’t leaking before, I’d run it 👍
Reactions: 1
an update on my 289 block.
i was thinking about it and when i was cleaning the waterports (behind the freese plugs) i had taken out alot of iron litlle pieces that did stick to my magnet and after a lot more investigation its from the piece thats missing out of the casting.
so last day i exchanged my old289 cilinderheads and 0.030 over pistons with a other and good 289 block . i had only pay the seller the half of the block because of my cilinderheads.
the 289 that i bought is still a standard bore so i just need to bore it to 0.030 inch.
i'm gonna go with a 331 stroker ( no need for a 347 because of the max 350hp T5)
there are a few options of +5cc , +6cc or a - 6.8 CC piston head volume.
i wanna buy heads from skip white performance or flotek( debating between flat tapped or roller lifters)
The NKB FORD aluminum heads have 62cc combustion chambers with 190cc runners, 2.02/1.60 stainless valves from comp cams or melling max 535 lift for hydraulic flat tapped
roller heads are to max 600 lift
Flo-Tek Cylinder Head Assembly 203-505FT; 180cc Aluminum 58cc for Ford 302/351W
i know i wanna cheap out on heads but for max 350 hp and that my prices (Europe)are an extra of 30 percent on top of the ( part cost + shipping) the expensier heads are gonna be 3000 dollars for me.
which of the 3 options is the best option ? +5 , +6 or -6.8cc combustion chamber ?
we have 95 ron but with 10 percent of bio fuel in it and 93 ron with a 5 percent bio and a few more expensive gasstations without the bio crap in the fuel
thanks for helping
See less See more
Domed pistons will raise compression but also require more timing because of slower flame travel and have higher octane requirements. I suggest flattops with valve reliefs; usually adding about 6 cc to the combustion chamber. They'll run best for a street oriented engine that you don't want to be octane sensitive. Some good brands to look at are Mahle, Icon, and Wiseco, preferably in 4032 alloy so you don't have to worry about expansion as much.
Hyper and cast pistons are sometimes a little cheaper, but forged pistons are often lighter, they're stronger, and if you have a tuning "oops" of some sort, they will tend to deform a bit before coming apart. A typical hyper or cast piston when pushed beyond its limits will shatter and do really bad things. With a forged piston, you have a chance to catch it before catastrophic problems occur.
Flo-Tek heads are actually decent castings, but if you have a choice, get the valves, springs, and guides separately - or get AFR Enforcers, which are very similar but come with much better hardware, and won't have weird problems like the heads popping off the valves.
For any street engine, you need to worry about dynamic compression just as much as your static compression number. 8.5:1 dynamic compression (which takes into account valve events and rod ratios as well as the static compression number) is generally considered a 'safe' number for pump gas. Some people advocate higher static compression ratios, like 11:1, but frankly, for a car that's driven a lot, it may not be practical. I would suggest something more between 9:1 and 10:1 for a car that isn't going to be on the track.
Your quench should be somewhere between .037-.045 to get best effect, giving you improved performance and resistance to detonation. Too little, and the pistons can smack into the heads. Too much, and your engine will be much more octane sensitive.
See less See more
Reactions: 1
1 - 20 of 88 Posts
