The engine doesn't know what size of intake valves the heads have. At this level of build, valve size is a moot point. I guess my question would be, why would 165's do "far better" on his engine?
Valve size is never a moot point, every characteristic has its place. Curtain area under a valve is especially important mid lift. However, when I said "far better" I didn't realize TW made a 170cc runner. Like I said, my unhappy experience with Trick Flow was earlier when they used to break guides left and right, so I stopped using them. I wouldn't go cheap then with my name on it and they left a bad taste in my mouth. I have seen the 5.0 crowd do OK, but have never seen any of them with high miles, so I'll still wait for the guy that can get 10 years out of them
But back to the port size 165 vs 170, not a huge difference, in either case, the port will be responsive enough for a relatively low rpm, small cid motor. A 185 or bigger would be lazy with his small cid, short cam motor
When just comparing the two heads, the Trick Flows are cheaper, have better components and have an improved intake valve location over the inline AFR heads which are for the most part a ported stock head in an aluminum casting.
Cheaper is good, I'll give you that. The AFR is FAR from a stock head, the exhaust flows more than a stock intake. The TW heads are a neat concept and have followers I can see, but MANY people make a lot of power with AFR too. If you like them though, life is good and keep using them, I have no reason to argue with you and at the same time I don't see you guaranteeing anything I build
However, not sure about the component claim, first, rarely does an off the shelf head meet the specs for builds with my name on it, and rarely will an early flat tappet 302 be able to run the springs that come on either the AFR or the TW. I also have no way of verifying the parts are "better" when I haven't seen anything substandard on an AFR head. Run what you want, but I run in circles where AFR is the quality head.
When comparing cylinder heads, peak flow is just a very, very tiny part of the equation. More important is average flow. If you compare the three heads from .300"-.500" (any lower does not factor into hp and higher lower flows can actually hurt hp/torque and anything above .500" is moot since his engine is not cammed that large) you will find that the Trick Flow averages 229.7cfm while the AFR 165 is 206.0cfm and the AFR 185 is 230.0cfm (data from Stan Weiss head flow
Stan Weiss' - Cylinder Head Flow Data at 28 Inches of Water -- DFW / FLW Flow Files for use with Engine Simulation Software).
This isnt my first rodeo, you are completely ignoring the exhaust side as well as the effects of overlap with a better exhaust port. Not only do I use Stan's site, I have talked to him many times about his numbers and a million other topics and those numbers are not exact, they are supplied by many people on many benches, to include manufacturers.
Hell, my own KC Stage 2 heads on my 489 had a flow sheet that said 330, we flowed them and they wouldn't break 285, sent them back, he claimed they were better and flowed 330 :shrug:, back on the same bench they were 285. In the end we worked them to flow low 320s. benches are ALL over the place and using that website as the only input, whether it be peak flow or average isn't accurate unless they were flowed on the same bench, same air, same inlet design.
Matter of fact, you are falling into your own "flow number" criticism, on a bench, the TWs flow more at various lifts, add a slightly smaller runner and a noticeably better exhaust port on the AFR 165 and you get more authority on the runner during overlap, this isn't measured on a bench.
Proper sizing of the header primary pipe causes what we call "supercharge effect" which actually fills the cylinder due to exhaust gas pulses pulling more in through the intake during overlap. I am not saying that the TW 170 vs AFR 165 is one way or another, but I am saying a head with more exhaust flow will hang on longer at the top of the curve and can make more torque on the way up. No specifics as I said, I haven't used the TW, but academically, there is more than just mid lift flow. I'd have to test both in a specific combo to see if the 170 made more.
If they did though, I promise I'd admit it, I have no loyalty to AFR, I am just very pleased with them out of experience.
For this build in all honesty the cylinder heads, while the most important upgrade on an engine in terms of performance are not going to mean much without further upgrades. If you plan to make performance improvements in the future then cylinder head selection is that more important. Personally, its a no-brainer for me when choosing a head for a 302. The Trick Flow 170 is as good as it gets for the money. With very minor cleanup of the intake ports you can really wake these heads up. The AFR heads are just too much money IMO for what you get. Yes they perform well but not when you consider what can be done to the Trick Flow heads with the money you've saved.
It will be important for you to find out what pistons you have, how far they are in the hole and what size valve reliefs they have when you go to install your cylinder heads. Milling the deck of the cylinder heads to get an appropriate compression ratio is going to do about as much for you as improving your cylinder heads.
Even that is ok advice but a bit off, if the pistons are deep in the hole, milling the heads will just make a detonation monster and be limited by fuel, if indeed the pistons are so low that he needs to cut a head, then he has the wrong pistons and should set up for the proper quench, something that will allow more power with less timing and a better burn overall.
Overall though, you can defend your TW heads, I am not fighting you, run them all day long and if they work well for you I will commend you for a great build, but AFRs run real strong and as a guy with a TON of builds under my belt, I like the AFR and I know the guy wont be disappointed.
The truth is, he probably wouldn't be disappointed with Edelbrocks, ANYTHING is going to be much better than the stockers
I really don't want to have, or win, an argument, but I have had very good luck with AFR and still recommend them
