After taking in suggestions on seam sealing It looks like I screwed the thing up afterall.
I have my cowl painted with two good coats of corroless and my engine compartment with Chassis Black. I then go over the seams, That have now been painted as well, and after about 15 seconds the corroless and the Chassis Black are lifting.
I do not know what to do. I was able to scrape the stuff off most of the seams except the cowl. The paint and seam sealer just wiped off. All around each hat is wrinkled bubbled seam sealer. Underneath what I did scrape off was wet paint? The seam sealer must have penetrated the corroless and Chassis Black. In some places I tried Por15 there was no lifting and no problems.
I had used some enamel primer in some areas not treated my the corroless and the chassis black just came off almost as fast as i put it on. The primer is stil there and still holding on strong.
What the heck did I do wrong? I used 3M brush on seam sealer. Directions did not warn about lifting. The Chassis black can did though. Can I just let the cowl dry and hope for the best? I know the answer is to remove the stuff and start over. But, where? I guess I could strip and go back with the POR15.
Confused, Pi$$ed, and quite frankly: buzzed from the fumes!
