If you have a bolt on (70 version)they fits both cars 69/70. That ones will go in, a lots better,than glued ones.
You have to have door hinge pins in very good condition, no free run. Then you do have 7 points of adjustement. Sliders (bars where window slides) can be adjusted on the bottom of the door for about an inch back and forward. Top of the slider bars can be adjusted left and right (close to 3/4")
Then you can adjust the hight of the rollup of the window above the door lock from inside face of the door (2 screws).
Than on the other side (hinge door side)u have a 1 bolt. These are the stop brackets. Than one more bolt which holding the rollup arm in the middle, which will udjust geometry when rolling up to the stop brackets.
I can tell you that took me about 3 hours per window. On the driver site, I had to move weather striping about 1/4" inside to be able to properly seal.
Hope this helps.
Hope this helps.
