I am trying to replace the shifter bushings on a 66 auto and I cannot get the shifter arm separated from the shifter shaft to install the bushings. It seems like these two parts are fused together. Is there a trick to doing this??
Any help would be appreciated.
-keith
I took my '65's out last week to replace the shifter lever and t-handle. It kinda hung up a little. I think I used a big screw driver and pecked it a couple of times and it just came right off. You're looking at the shift lever from above, and have already removed the nut, right?
Phil
Yes, I'm looking at it from above and the nut has been removed. I've tried pulling it, twisting it and banging it a little but it won't come free!!!
If it's the same as a '65, the shifter lever has an oblong slot in it that fits over an oblong shaft on the shifter mechanism. I'd suggest a few shots of PB Blaster and a bigger hammer.
Good Luck!
Phil
Discussion Starter · #5 ·
Phil,
Thanks for the help. Yes it's the same as a '65. I will try with a much bigger hammer!!!!
